Hi,
Do not turn on your laptop!
Disconnect the charger (if connected) and then remove the battery (if possible) to minimize any further damage to the laptop caused by the action of liquids on electronic components. Having power available to the motherboard can make it worse.
If the laptop has an internal battery (you don’t state the make and model number) the laptop needs to be opened and then the battery needs to disconnected from the systemboard.
After this all the affected parts need to be thoroughly cleaned using Isopropyl Alcohol 90%+ to remove all traces of corrosion and liquids.
Hopefully after this it might work properly again.
Here’s a link to a guide which explains the process.
Electronics Water Damage
Here’s a link to the ifixit Chromebook guides, (hopefully your particular model is listed) which should help to open the laptop so that access is possible.
If this seems too daunting a task, contact a reputable, professional laptop repair service experienced in liquid damage repair and ask for a quote to repair the laptop. If you decide to do this, do it sooner than later as the problems may get worse. They certainly won’t get better by themselves
Votato
Annulla
Punteggio
4
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti
hi, idk how to fix a chromebook with beetroot juice on it.
da Michael Subin
me to i spilled juice and now the sound doesn't work
da Ebtihal Omer
