TCL Half of screen darker
do I need to replace leds when screen darker on half of tv
Questa è una buona domanda?
Sherri B it is possible that this is an LED backlight array issue. Post some images of what your screen shows. Use this guide Aggiungere immagini ad una domanda for that. You also want to try to reset it. Remove all input sources as well as soundboard etc. Then unplug the TV. Either hold the power button down for a few minutes or keep the set unplugged for something like 30 min. Then connect only one video source ( a local source like DVD/BR/ or Game console would work. Stay away from cable or sat box for now since they can actually be part of the problem).. Then plug the TV back in and see if that made a difference. If it did not you will have to remove the back cover from your TV and take a look at the board. Check for any obviously damaged looking parts and reseat the interconnect cables. Post some pictures of the boards as well. You will need a multimeter to check the LED connector voltages etc. TCL is still a bit of an off-brand make so there are not a whole lot of schematics etc. available so we need to rely on your images to see if we can find out what's going on.
May be? Just open and see if there are any “leaked capacitors”…
I repaired a 43P20US TCL smart tv right side darker and eco setting on would make the screen go black at 4 sec intervals. Checked power supply okay. Secondly I decided to go straight to TCON board it was pretty dusty so decided to clean connections with pencil eraser. Retested and solved both issues. Hope this helps.
left screen is darker coler good. just got replacement boards from shopjimy.tv works but still darker left screen.i do think the tcon board was bad.it is a better pic……but no lines in the screen just little darker on the left.the new boards and all was replaced pic not disorteing now…is the update bad??????????????????????????????
yep might be just that///////
Ultime 24 Ore: 6
Ultimi 7 Giorni: 63
Ultimi 30 Giorni: 300
Tutti i Tempi: 8,684
