Salta al contenuto principale
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Domande Visualizza tutte
fan doesnt run automatically
when i use my imac then fan never runs atuomaticaly even though the top is burning but it works with smcfan control how do i make it run automaticaly?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Do an SMC reset. Unplug the power cord and let it sit for a few minutes. How can you tell that the fans are running at all? These machines idle very quiet. Install the iStat Pro widget to monitor fan speeds and temps.
Punteggio 2
2 Commenti:
i already have stat pro its only on 1199 even when its burning hot
da
Try smc fancotrol (found easily via google) to ramp up the base speed of the fans. Something seems to be fishy with either the sensors or the smc itself on your machine. Unfortunately i can't tell more without actually seeing the computer. Doublecheck all wiring on the logicboard.
da
heres info.
  • try using a different fan
Punteggio 0
Aggiungi la tua risposta
mop2011 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 478
