Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
6s stuck on apple logo, tried all the normal solutions.
Hello.
So I went to fix my friends iPhone 6s for what I assumed was just a simple battery problem. His phone randomly stopped working and got stuck on the apple logo, unable to go to the homescreen.
Tried a new battery, tried other batteries, same issue. I then took his screen/the new battery and tried on a different iPhone 6s and they both worked perfectly fine.
I tried a new screen on his phone, same issue. Tried unplugging all the cables (charging port, home button cable, front facing camera, back camera). Pretty much tried everything I know on how to fix this type of solution and unfortunately had no luck.
As a last resort I wanted to come here and see if anyone has any other suggestions for me to attempt. It stays on the apple logo forever before it has a quick flash, then back on the logo. Then eventually the screen just goes black. Appreciate any suggestions and help
Questa è una buona domanda?
Punteggio 0
12 Commenti:
Try updating it through iTunes and see what happens.
da
Okay, will def give that a try.
Thanks
da
Could be that he doesn’t have enough space on the phone to start. Had the same issue and I had to completely restore the phone
da
watch this video will help you fix your stuck on logo iphone https://youtu.be/0XGMFmHLFCw
da
Watched the video, I know about 3utools. Doesn't the software cost money?
da
Mostra altri 7 commenti
Aggiungi un commento
1 Risposta
Software crash thats why is not loading, try to put it in DFU Mode , if you get it to DFU mode there’s the issue. you can try to update it but it might fail , if you flash it from 3Utools still gonna restore the device
Punteggio 0
1 Commento:
It's in DFU mode, tried to flash it with 3utools while retaining users data and failed at 33%
Having trouble getting it out of DFU mode now.
da
Aggiungi la tua risposta
Ian Romprey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 101
