Salta al contenuto principale
Rilasciata a novembre 2016, si caratterizza per l'aggiornamento hardware per giocare in 4K e prestazioni PSVR migliorate.
387 Domande Visualizza tutte
Snapped disc stuck in drive, wont eject manually.
My son, in temper, snapped a disc panicked and push half the broken disc back in, it wont come out automatically or manually (I’ve tried taking off the top and turning the manual screw) I took it to a repair centre who say that the only way to fix is it to replace the drive but that would be expensive, any ideas at all?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
unless the snapped disc damaged the drive, the shop is just trying to get you on a replacement.
it is 100% possible to remove the disc drive and take the drive itself apart to remove the disc. I’d find another shop that is more helpful and willing to work with you on it, removing the disc and charging you a labor fee if the drive still works and if it doesn’t then offer you a replacement cost.
you could also try it yourself, but there are dangers involved for an expensive machine like this. I believe there’s an ifixit guide on removing the disc drive however
Punteggio 0
2 Commenti:
Do you have a link to the guide? Im brand new to this site I found it looking for any help to fix it.
da
Aggiungi la tua risposta
Shellie Palmer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 711
