Salta al contenuto principale
La TI-30X IIS è una calcolatrice scientifica con funzioni trigonometriche introdotta per la prima volta da Texas Instruments nel 1993. Utilizza sia una batteria ricaricabile che una cella solare per l'alimentazione.
The LCD readout symbols are fading. Is there an easy fix.
I have several TI-30X iis calculators I use in my classroom and the LCD readouts are fading. Is there an easy fix or are they shot?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Your calculators might be having a similar issue to the TI-84 Plus calculators where the ribbon cable is degrading. If you have soldering experience, then you might want to take a look at this guide here: Sostituzione della batteria per Texas Instruments TI-30X IIS for instructions on how to take apart the calculator. Refer to this topic on Cemetech for instructions on how to fix a ribbon cable: https://www.cemetech.net/forum/viewtopic...
Punteggio 2
2 Commenti:
sounds like a lot of work for a non -techy
da
If you don't want to try fixing the ribbon cable, then you can try Duane's suggestion of replacing the battery and adjusting the contrast. Although I find it unlikely that's the issue, hopefully it is something as simple as that. Otherwise you'll have to find a friend or student that's willing to take on such a project, buy a whole new calculator, or just deal with a partially broken screen.
da
Sounds like the Contrast setting is lowering, how are the batteries also?
Punteggio 0
2 Commenti:
Poor description on my part. You can see some numbers or parts of numbers.
da
I stick with my suggestion of adjusting contrast, otherwise, time to replace the unit.
da
Aggiungi la tua risposta
Doug Dahms sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,922
