Salta al contenuto principale
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Domande Visualizza tutte
Why can I find a replacement glass for MacBook Pro but not Air?
I have searched all over the internet to purchase replacement glass for a 13” Air.
Several inexpensive results come up for Pro replacements but the Air results are sparse. Those results that do come up are far more expensive then the Pro results; what gives?
Questa è una buona domanda?
Punteggio 0
3 Commenti:
As you didn't tell us your exact system we can't point you to the needed part.
da
MacBook Air (13-inch, Late 2010)
Graphics: NVIDIA GeForce 320M 256 MB
da
Here's the needed part MacBook Air 13" (Late 2010-Mid 2011) Display Assembly. I recommend going this way Vs trying to replace the LCD panel its self.
While that can be done getting the panel alone, a good working display panel is often hard as they are so fragile when they are shipped as a single panel.
We bought them in a crate of 20 directly from China and even then we got a few broken ones.
da
Aggiungi un commento
1 Risposta
Very simple! The Airs don’t have a cover glass unlike the MacBook Pro’s.
Here’s the breakdowns of the two different displays:
Older Unibody: MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement
Air’s & Retina models: MacBook Pro Retina Display Teardown
As we can see the newer designs use a single plate design where the older use a cover glass.
Immagine MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD
Guida
Difficoltà:
Molto difficile
Immagine MacBook Pro 15" Retina Display Mid 2012
Guida
Difficoltà:
Moderato
Punteggio 0
Aggiungi la tua risposta
ViVi Bowers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 70
