Salta al contenuto principale
Informazioni di riparazione per il Samsung Galaxy J7 Refine, rilasciato nel 2018. Numero di modello: SM-J737PZDEBST.
Incoming doesn't work when WiFi connected.
My phone will not receive incoming calls and texts of I'm connected to WiFi. I've looked through every possible setting in my phone, I refreshed network, I've factory reset my phone. If I restart it, everything will come through and then go back to not getting anything. If I have WiFi off, everything works. I've gotten nowhere with my phone provider, even though contacting them 5 times. I'm at a loss.
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Is your SIM card activated? Do you have wifi calling enabled?
da
Yes it's activated, and I have no idea where that is, I'll look though. All my settings for calls are what set to when I factory reset my phone, so I should be good.
da
The only solution is replacement, S9 or 9+. I recently got the 9+ to replace my J7, which was designed to fail within 18-24 month, for sure.
da
Aggiungi un commento
1 Risposta
Go to your dialer (phone icon) hit 3 dots in top right corner. Disable wifi calling then restart. Try receiving a call
Punteggio 0
1 Commento:
There is no such option in that menu, or when I click settings from that menu.
da
Aggiungi la tua risposta
asmith298828 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 13
Tutti i Tempi: 259
