Salta al contenuto principale
Impastatrice planetaria a testa inclinabile KitchenAid Artisan Series da 4,7 litri, numero di modello KSM150PSER. Tutti i modelli che iniziano con KSM150PS sono lo stesso dispositivo, cambiano solo i colori.
Meat Grinder Attachment Won't Grind...It Sticks
While grinding meat using the grinder attachment, the sound of the motor has changed and then the grinder stops. I suspect it needs to be cleaned. What is the recommended method and materials to do this?
Questa è una buona domanda?
Punteggio 1
1 Commento
The problem is not with the attachment. It is in the Kitchen Aid mixer.
da
Aggiungi un commento
1 Risposta
Risposta più utile
While the change in motor noise is most likely a motor fault, do examine the grinder itself. If the front ring is too tight, the mixer will grind (pun alert) to a halt.
If the grinder is adjusted properly, the motor’s worm-follower gear is the next thing to look at. It is designed to fail and save the motor from burning out.
The Service Manual can be found at:
++http://www.kitchenaidparts.eu/documents/...
Punteggio 1
Aggiungi la tua risposta
Chuck Pelto sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 4
Ultimi 30 giorni: 24
Tutti i Tempi: 2,368
