Salta al contenuto principale
Il Samsung Galaxy A3 (2017) è uno smartphone di classe media della serie Galaxy A. È stato presentato da Samsung nel febbraio 2017 insieme al Galaxy A5 (2017) e al Galaxy A7 (2017).
16 Domande Visualizza tutte
Using smd rework station
Hi,
I am quite new to mobile servicing. I want to use smd rework station. While doing so, there are much opportunities for the damage of nearby components . Are there any ways to avoid damaging such nearby components?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yep, there two ways that I use to shield surrounding components of what you are heating up.
  • Apply Kapton (Yellow non-conductive) tape to surrounding components
  • Use thick metal objects that absorb heat well like a penny / coin (if needed)
Pre-heating the board to something like 80°C will make it easier to remove the component being heated.
Avoid using a small nozzle as they are prone to blowing surrounding components away for the heat gun and don’t heat components for too long when putting them on to the board.
For a lot of my re-work I use 380-480°C depending on the heat required, this will vary between hot air stations so might want to practice removing and putting back SMD components / BGA components on dead boards first.
Punteggio 1
Aggiungi la tua risposta
S.Kumar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 41
