Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
873 Domande Visualizza tutte
Replace my iPhone 8 Wifi Antenna?
My iPhone 8 will no longer connect to any WiFi networks…in fact the option to connect to WiFi is greyed out. I’ve tried everything to get it to work. Sound like a hardware issue? Will replacing the antenna solve my problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the antenna were broken you would still be able to get WiFi signal, it would just be very faint. If the WiFi option is grayed out entirely that indicates an issue with the WiFi chip on your logic board. You’ll need to find a microsoldering professional who can fix that chip for you, it isn’t a DIY project.
Punteggio 2
Aggiungi la tua risposta
RAF sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 117
