Salta al contenuto principale
The Dyson Ball Animal was released early 2014, identified by model number DC 65. This Dyson vacuum was built off of the previous DC 41 model. The DC 65 model provides better suction power and the brushbar is 25% more powerful. It also is suitable for two more surfaces.
Hand vac won’t suck hard
The hand vac flex tube on the bottom that moves to direct suction has holes in it. I can see them but don’t know how to fix
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If your vacuum cleaner loses suction from its nozzle or hose, see the Dyson Ball Animal Has Loss Of Suction In Hose problem page for possible causes and solutions.
See if the following is of use:
Sostituzione del tubo di Dyson Ball Animal
If applicable then replace the hose or use duct tape for a possible quick cheap fix.
If not, might want to post a photo or two showing your problem.
Aggiungere immagini ad una domanda
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Dyson Ball Animal Tubo
Guida
Difficoltà:
Facile
3 minutes
Punteggio 1
Aggiungi la tua risposta
Robert Guerriere sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,309
