Salta al contenuto principale
Repair information for Lenovo Thinkpad Yoga 2013
21 Domande Visualizza tutte
Windows not recognizing downloaded screensaver files
Yeah, so my screensaver’s aren’t being recognized. I’ve updated, and restarted my laptop, and still it won’t allow me to configure the screensaver.
Image Below:
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi @jessicapfawkes ,
Do you get an error message of some sort?
Did you try installing it this way?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Haha Windows was having a panic attack. Turns out the Screensaver’s auto detected, I don’t need to manually install it.
Thanks for trying to help!
Punteggio 0
Not all executable files can simply be renamed to act as a screensaver. When Windows finds a file that appears to be a screensaver, it will expect it to respond appropriately to certain command line arguments, specific to screensavers. If it does not, the file will not be run as a screensaver.
Just to make sure, try a few other screen savers and see if they don’t give you the same problem. If they don’t, then the files you already downloaded may be incompatible with Windows.
Punteggio 0
Aggiungi la tua risposta
Rosa Avrigari sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 86
