Power windows, dash lights ,tail lights, signal lights not working
Hi there so I bought a 04 tiburon the only lights working on it are the hi beams low beams fog lights and done lights the rest are not working. I replaced fuses and the bcm and still no luck the tail lights won’t turn on but when I hit my brakes lights come on. Any ideas?
Questa è una buona domanda?
Punteggio
0
Hi @dford97 ,
You said that you replaced the fuses but did you check that there is 12V power actually available at the fuses for all the different lights etc?
Use a Voltmeter or a test lamp and check if there is a +12V power supply at the fuse point.
If there isn't it may be a blown main fuse which is usually located at the battery's +ve terminal connection point or a problem in the back of the fuse block.
da jayeff
