Salta al contenuto principale
Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 Domande Visualizza tutte
Spilled water on my laptop it wont turn on,what do I do?
Something similar happened to me, I spilled water on my keyboard.. The screen immediately went black. I quickly wiped it the water off. After 7-20 minutes I flipped it upside down for a couple hours. I did the same outside.... It’s been about a week and can someone tell me what damage I’ve done
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @liahhh ,
What is the model number of the laptop?
da
Aggiungi un commento
1 Risposta
As with any electronic device containing circuit boards and IC chips, water and moisture are the enemy. It is not only the water that can short out the intricate circuits, but the minerals in the water. When dry, the minerals are left.
I suggest:
  1. Remove the battery, and do not plug in the charger.
# Disassembly the unit and give it a complete inspection. Look for traces of either water still there and minerals left behind. Calcium may leave behind white traces.
# Check for components that are evidently blown. Like varistors, capacitors, etc.
# Depending on what you find, you may need to give the circuit board a bath to clean off residue. Use 99% pure alcohol for this.
  1. When its clean and dry, reassemble it and see if it will work.
Punteggio 0
Aggiungi la tua risposta
Chloe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 28
