Rinse cycle refill extremely slow
Refilling on rinse cycle really slow.
Questa è una buona domanda?
Hi @cormier ,
What is the full model number of the washer?
Are you doing a hot wash cycle or a cold wash cycle?
With most washers when doing a hot wash cycle, after the hot wash, the rinse is always cold water, not hot water.
If you are doing a hot wash, try a cold wash and check how slow it fills when first starting the wash.
If it is also slow, there may be a blockage in the filter on the cold water inlet hose connection, where the hose screws into the back of the machine or perhaps it may be a faulty cold water inlet solenoid in the machine, either blocked or only partially operating.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 560
