Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
MacBook Pro Display Anomoly Replacement
Hello! I have a display anomaly on my Macbook Pro screen and I unfortunately kept putting it off to the side and the warranty has now expired. Is there any way I could get it repaired? Or know how much it’s going to cost for such a small issue? Or will I just have to live with it?
Questa è una buona domanda?
Punteggio 0
2 Commenti
How about posting a few pics so we can see what you are facing Aggiungere immagini ad una domanda Otherwise make an appointment with an Apple Store.
da
@danj Just uploaded the picture!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I think you’ll just need to live with it. Sorry ;-{
You appear to have a slight defect in the LCD so the light from the backlight is slightly brighter at that location. Replacing the display is about $600 just for the part. You could try to visit an Apple Store to see if they will replace it under the extended warranty problem for backlight flex cable defect. So if that is also happening then you might get it still fixed for free.
FYI:
Punteggio 0
2 Commenti:
Thank you. Unfortunately, I have a 2017 model so it might take convincing. Also, doesn't the Mac have to exhibit one of the issues/effects before getting a replacement?
da
The point was IF your display had this defect you might be able sneak it in under that program. You'll need to think this through a bit as I can't tell you what to do to make the display to need to be replaced can I >>Hint<<
da
Aggiungi la tua risposta
Aden Tran sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 124
