Salta al contenuto principale
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 Domande Visualizza tutte
Why won’t my Nintendo 2DS XL turn on?
Recently, my 2ds xl will not turn on no matter what I do! Just a Week ago it was working perfectly now it won’t turn on? If anyone can give me some advice that pI duo be greatly appreciated :) thank you.(also even if I charge it no lights flash it just won’t turn on
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@hobi_j check your charger to make sure that it is working. After that check the charging port to make sure that it works and check/replace your battery. That way you have a known well starting point for further troubleshooting. If all of those parts are functioning you will have to disassemble your 2ds xl and check for any obvious damaged components on its motherboard. Post some good pictures of that with your question so that we can see what you see. Aggiungere immagini ad una domanda and here is the teardown Nintendo 2DS XL Teardown
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine New Nintendo 2DS XL
Guida
Difficoltà:
Moderato
Punteggio 0
1 Commento:
Uh yeah ok. I am currently not at home where my 2ds xl is but once I arrive I will be able to show some photos of it. Also I will be getting a new cable to see if that works since I have been using the same cable I
Got from my dsi in 2012. (I think I may have lost my 2ds xl charger I don’t know)
da
Aggiungi la tua risposta
Joel Serrano sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 141
