Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Everything works but calling
I cant make calls with iPhone 7. Everything works 4g, wifi, SMS etc. But when i try to call with it it the calls just doesnt go through. Am not able to call the number with other phone either. How can i fix this
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like a 3G antenna fault. There are two antennas that go to the board near the screen / charger port connector. Sometimes removing one of them will get 3G working properly without notable signal degradation.
Has any parts been replaced on the phone before the problem occured?
Punteggio 1
1 Commento:
Hi. Thanks for your answer. I do not know if anythings been replaced since i got the phone used but will try to replace the antenna
da
Aggiungi la tua risposta
Säti Säkki sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 33
