Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Why my iPhone 7 shows no modem firmware and battery only show 1%
Hi i wanna ask why my iphone 7 showing no modem firmware and battery only shows 1% after i replace the tristar. The phone is power on after plugged into usb cable but it cant charge and only shows up 1% is it tigris defect? Or any batt_swi line got shorted? And my modem firmware is not showing either is it the wtr rf ic defect? Mine is intel modem
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It’s hard to say exactly what the issue is but it obviously has to do with your Tristar replacement attempt. The first thing to do is to inspect your work. Look for bridged or dislodged components near Tristar and the surrounding area. You may want to consider reballing/replacing Tristar again. If you are inexperienced, then it is probably an issue with your technique. If you are experienced, then you should be able to tell of the placement looks good or not. For the SWI line, open up the schematic and follow the netline and inspect all of the components on that line.
As for the Modem firmware issue, this is most likely collateral damage. Again, check for bridging/dislodged components. However, focus on your Tristar issue first.
Punteggio 2
1 Commento:
Thanks i will try replace tristar again
da
Aggiungi la tua risposta
azmi muwahid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 123
