Salta al contenuto principale
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
SUD and F35 error codes
I have tried many things to clear the Sud and F35 error codes and nothing seems to work. I replaced both the pressure switch and drain pump, also tried changing the CCU board but nothing seems to work. The wire harness is also fine but the sud and f35 eorrors still appear. Can anyone help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
pigterrio okay so let’s clarify:
UD : The Sud error code is used to indicate there are too many suds for the washer to remove. This is often caused by too much detergent being used or non HE detergent being used in an HE machine.
After 4 minute the SUD will be displayed and 4 minutes later the F02 will be displayed
Check the drain hose and make sure the hose is not plugged or kinked
Press pause/cancel twice to clear the display
Run the machine through a Rinse/Spin cold water cycle then a Normal cycle without adding any additional soap.
F35 = ANALOG PRESSURE SENSOR FAILURE This failure is displayed if the analog pressure switch has a calibration error. The "F35" error code is indicating a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch.
Check if pressure hose is fixed correctly.
Check if the Air trap/Air dome is not blocked.
Check if the hose is not blocked.
You told us that you did replace the pressure switch but not if you replaced the tube or at least checked it. Let us know what you find.
Punteggio 3
2 Commenti:
Thank you for your reply, we did all that was stated above, however, after putting the machine on rinse and spin and normal we noticed that it takes in a small quantity of water before the sud error appears. After it appears the water stops and the machine stops all functions for a couple minutes before it then drains the water and the F35 error appears. There is no spin from the machine it just fills and drains.
da
We have exactly the same issue, did you found what is wrong?! And the solution?
da
Aggiungi la tua risposta
pigterrio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,242
