Salta al contenuto principale
Rilasciato nel 1999, successore del PowerMac G3 originale, 300-450 MHz, 64 o 128 MB di RAM, HDD da 6 o 12 GB
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
Questa è una buona domanda?
Punteggio 0
1 Commento
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
Punteggio 2
Aggiungi la tua risposta
edith sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 11
Tutti i Tempi: 1,496
