Salta al contenuto principale
La linea di computer portatili MacBook Pro di Apple per utenti avanzati e professionisti. La linea MacBook Pro include varianti da 13, 14, 15, 16 e 17 pollici, e le revisioni principali sono definite da Pre-unibody (originale), unibosy, display Retina, Touch Bar e SoC (system-on-a-chip).
20012 Domande Visualizza tutte
Domanda Chiusa
Why no lights?
No, Apple logo light, No keyboard light and no display light. Can anybody help
Questa è una buona domanda?
Punteggio 0
2 Commenti
I can see the apple logo very faintly on the screen. Tried a reset and no luck.
da
It sounds like it is booting, but cant see anything on the display. The power on LED is the only light.
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Have you tried an external monitor? If you have video with the external monitor the likely problem is the LCD cable or the LCD itself. If you don't then you may have a logic board problem. Ralph
Punteggio 3
Does the computer boot at all or are you totally dead?
Punteggio 0
Punteggio 0
1 Commento:
If you hold a flashlight up to the display can you see any faint graphics at all?
da
I cant see anything on the display. I wouldnt think the LCD monitor cable would have anything to do with the keyboard backlight, but I could be wrong.
Punteggio 0
Could still be a bad battery, or bad pram battery, you may want to try resetting your SMU. and it may not be a bad logic board, could just be bad dc-in
Punteggio 0
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,162
