Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
iPhone 6 Plus not powering on after being off for a long time
So one day I left my phone in a drawer and forgot to power it off fully. It’s been months before I found it again and when I plugged it in, nothing came up on the screen. I left it overnight and still no response. I know the charger is good because it works on my other phones and the phone had worked previously before I left it in the drawer. I’ve tried hard restarting to attempting DFU mode and nothing. This phone has had battery drain issues even after a factory reset so I’m not that surprised that the battery was bad but I was expecting it to boot up. Anything else for me to try?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the battery was fully drained and totally dead the logic board will not send any power to the battery
Punteggio 1
5 Commenti:
So is there anything that I can try or not?
da
Replace the battery.
da
Boost the battery with a power supply or one of those plug in battery charger boards if it keeps depleting below a certain tolerance and wont charge again then replace battery or if battery life isn't good... if the new battery doesn't fix it then replace tristar, thats the order I normally do it in cos sometimes the battery is perfectly fine it just gone too flat that one time and just needs a boost. Sometimes even just holding the power button and plugging the cable in and keeping the button held has worked for me but I might have just imagined this and the battery might not have been that dead lol
da
I replaced the battery and it seemed to fix it. Thanks!
da
Glad you were able to fix it! Sorry I myself hadn't replied, I don't tend to the forums very often!
da
Aggiungi la tua risposta
jimmysofat6864 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 318
