Is this a bad GPU and can I still fix this?
My iMac late 2009 (2.66 GHz Core i5, model A1312 aka EMC 2374, iMac11,1) is not booting in regular mode. The screen breaks up and the boot stalls.
It boots in safe mode with some glitches (e.g., the mouse pointer has a square grid of horizontal lines).
From what I have discovered so far, this is most likely a GPU glitch. I have seen ideas like pulling out the graphics card and baking at 200°C, which strikes me as hit and miss and reballing the BGA (for which I would struggle to find a shop).
Best option would seem to be to replace the graphics card, for which I can get local help (I live far from big cities).
I did a quick scan through parts on offer at the ifixit store and most are for later models and only show compatibility for those exact models, though I also note that some later models ''should'' work on this one.
So: 2 questions:
- Is this actually a GPU problem?
- If it is, what is my best option for a replacement (including part numbers for later models that are known to work, if I can’t get an exact replacement)?
If I do go part replacement, international shipping is an inhibition on claiming on warranty or refund so it would be good to get this right first time.
Questa è una buona domanda?
3 Commenti
I would give diagnostics a try. Do you still have the grey CD/DVD disks that came with your system? If you do one will be the diagnostic disk. Do you get an error code?
If you don't have the disks see if the onboard diagnostics works. Presee and hold the D key when you restart your system.
Mac startup key combinations Apple has messed up the digs on some versions of MacOS installs so it may not work. Did you get an error code?
Let us know what worked and what the code was.
da Dan
I did run the supplied diagnostics and it came up clean. That I hope at least eliminated RAM as a problem. When you boot using the supplied DVD, it boots in a very minimal graphics mode.
I also ran Rember (http://www.kelleycomputing.net/rember/), which could not access all RAM since I couldn’t get it to take over the whole machine, but also did not throw up an error. I tried to find a way to run memtest on a minimal boot but the recipe I found would not boot (https://www.memtest86.com/technical.htm – possibly this model does not use UEFI).
It is annoying that Apple’s own test does not produce a diagnosis.
da Philip Machanick
All computer diagnostics are limited in some way. In computer speak we often talk about the inner world and the outer world spaces. The system diagnostics will often be limited to the inner world digital space of the system.
Let's look at a regular desktop PC which has PCIe slots the system makers drags won't test the other party adapters which are plugged in as the PCIe slot is the interface of the worlds, ust like the USB and DisplayPort/Thunderbolt ports as these too are the interface of there worlds too.
Here the MXM slot is the interface between the worlds so you would need the given vendors diagnostics for the given MXM graphics board.
But sometimes the lack of a test does not impede you from the needed diagnostic process. In this case your efforts have narrowed things down!
da Dan
