Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
597 Domande Visualizza tutte
2012 MacBook Pro pointer moves without input
Lately my mouse/pointer moves on up and down on the screen clicking files/apps on its own.
When an external mouse is connected the pointer moves very slow. This only happens occasionally. Is my touchpad going bad?
Here is the battery status.
Questa è una buona domanda?
Punteggio 0
1 Commento
Try to disable the touchpad (option to ignore touchpad when an external mouse is connected). Is it now working fine with your external mouse ?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Often times I need to replace the trackpad as liquids seep into the touchpad sandwich causing it to mis-track.
So you clearly need a new trackpad MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad and here’s the guide you’ll need to follow.
But before you go this far given the systems age I would check the battery to see if it too needs replacing. Install this gem of an app CoconutBattery. Take a snapshot of the main window and paste it here for us to see Aggiungere immagini ad una domanda. Sometimes the battery swells up pressing on the bottom side of the trackpad which can also damage the trackpad.
Immagine MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Prodotto
$59.99
Punteggio 2
3 Commenti:
I posted the battery status from the app. Battery appears to be ok. I already check for swelling too by opening the case. None on the bottom of the batteries are visible.
da
Good! Then you only need a new trackpad!
da
New trackpad is in route...I'll write back once it is installed!
da
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 78
