Salta al contenuto principale
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
My controller won't connect wirelessly anymore.
My elite controller won’t connect via wireless anymore. It will work with a USB cable but once the cable is removed it turns off. Can this be fixed by replacing the motherboard?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Not sure if this helpfull but I had the same problem with a regular controller. my problem seemed to be my rechargeable battery pack. every time one went dead I would swap it over to my fully charged one but I had to connect it via usb to sync it. all it would do is slowly flash when turned back on. the battary parks where running out of life I.e not holding much charge anymore because when using regular double aa my controller would sync fine like it does with my knew battery packs.
Punteggio 0
1 Commento:
Nope, the problem isn't the power source. New battery packs or new AA's don't work. Unless it's physically connected to the xbox via usb, it doesn't work.
da
If your Xbox One Wireless Controller is not syncing or connecting to your Xbox console, see the Xbox One Wireless Controller Won’t Connect to Console problem page for possible causes and solutions.
Punteggio 0
Aggiungi la tua risposta
Kainoa Kaku sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 583
