Salta al contenuto principale
Model A1288 / 8, 16, or 32 GB capacity
20 Domande Visualizza tutte
front panel digitizer removal
I purchased replacement battery kit and I am having difficulty removing the digitizer panel. The enclosed tools do not seem to be strong enough, it seems like the panel is glued. is that possible? and what can I do if that's the case?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hey, this is a bit late, but if you take a look at step 6 from the tear down guide:
Smontaggio iPod Touch 2a Generazione
You can see that there a small metal "latches" by every screw. Sometimes these bend inward making it very difficult to remove the screen.
Using a spugder try to push this away from the screen and towards the edge of the iPod as if you where try to expand the casing, then try to lift up the screen.
I always start near the volume rocker.
Punteggio 0
Aggiungi la tua risposta
nordixnet sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 691
