Salta al contenuto principale
will not power up
last night our lights kept flickering and now the wii will not power up.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
When you say your lights kept flickering, do you mean the lights on your Wii, or the lights in your house? Either way, I would suggest trying a new outlet or a new power cable before opening the device up. Everything inside the Wii is located on the motherboard, and while repair is possible, it's relatively costly. Should a new outlet/cable not solve your issue, here are the guide and the part.
Immagine Nintendo Wii Motherboard
Prodotto
$44.99
Punteggio 0
Risposta Più Utile
I had a problem with mine, we had a momentary power outage in the house and after the power came back on the Wii did not even light up. I unplugged the Wii and plugged it back it a different outlet. No help. Then I unplugged it and left it unplugged over night. The next morning when I plugged it in it worked fine. I spoke with some co-workers who also have Wii's and I have found that this can be pretty common. Anyway it's working fine now.
Punteggio 1
Aggiungi la tua risposta
Linda Quick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,618
