Salta al contenuto principale
Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
77 Domande Visualizza tutte
I am getting an error message from Amazon about not enough bandwith
I have a new smart tv, Vizio, and unable to play Amazon Prime videos  & tv shows.  The error message I get is not enough bandwidth, does this sound correct?  I am with Comcast.  Also, I can’t play Nextflix either, but when I talked to their customer service dept they said it is not a bandwidth issue, but has to do with the smart tvs and they have gotten many calls about it.  Not sure what to do. ???
Questa è una buona domanda?
Punteggio 1
3 Commenti
@oldturkey03  Thank you for your help.  I ran the test and for downloads I got 38.2 Mbps and uploads 5.9 Mbps so I am not exactly sure how to translate this to what you wrote.  Also, while I am on Netflix they have a test you can run and according to their site, I pass the bandwidth issue.  The customer service rep at Netflix said they think it is something else because many people are calling in about the issues.  Therefore, I don’t know what to think at this time.
da
@sanddancer those are some good numbers and plenty to stream. this does not sound like it is an issue with your hard ware.
da
Okay... thanks. I will follow up with Amazon and Netflix.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@sanddancer it will depend on what kind of network connection are you using. I’d start by performing a simple bandwidth connection check. Something like this this test should work. You will need a minimum of 2.5 Mbps and 7.5 Mbps for HD and > 12 Mbps for streaming on multiple devices. Let us know what you find out.
Punteggio 5
Aggiungi la tua risposta
Anne Jordan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 126
