Salta al contenuto principale
Fourth generation of the Toyota Pickup.
49 Domande Visualizza tutte
How would I replace the stock horn on my truck with an air horn
I have an airhorn kit but it doesn’t tell how to just install the horn without adding a big horn button. Can you install one of these and still be able to use the original horn buttons?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
alan.thomas65  your ‘85 seems to have a lot of horn problems going on. As for your air hon, that will depend what horn that is and what the wiring looks like. So, you may have to consider posting some pictures with your question.. Usually you just replace the standard horn with the air horn. That way your original button and circuitry is being used by the new horn. It may need some more wiring for the compressor but that will depend on the air horn not your Toyota.
Aggiungere immagini ad una domanda
Punteggio 2
Air horns need compressed air, so I would imagine you that you either need a compressor or an all in one system that produces the compressed air for that specific horn, like this for example…
https://www.ate-uk.com/air-horn-with-bui...
Punteggio 1
Aggiungi la tua risposta
alan.thomas65 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 860
