Salta al contenuto principale
The Alpine MRV-M500 can be identified by its model number: MRV-M500. It is a Mono V-Power Digital Amplifier released in 2013.
2 Domande Visualizza tutte
No sound coming from amp
The amp Powers up but I get no sound when I hook up speakers. I've tried several speakers. So it's definitely something to do with the amp. Blown channel? Can it be fixed and if so around how much for the repair?
Questa è una buona domanda?
Punteggio 1
1 Commento
Hi @cheddarbob ,
Have you checked the signal source to prove that there is something going into the amp?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The output FETS could be blown. You need to bust out an O-Scope to see if you are getting gate drive from the driver IC. These amps are like $80 used so you may have a hard time finding a tech to fix it for less than $100. Good luck!
Punteggio 1
Aggiungi la tua risposta
Robert schwarz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 666
