Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Fans spinning full speed, temperature sensors fine
== Ok so I have a a1278 MacBook Pro and the fan Is spinning at full speed. But it’s showing 0 rpm in macs fan control. And all,of the temperature sensors are fine. And i’ve done a smc reset and pram reset but nothing worked. I also replaced the fan that didn’t work either. So i’m pretty stumped right now
UPDATE 3/27/2019
I found the cause the fan spinning at full speed. The fan connector on the motherboard was loose so it may have not contacted the data pins. So I got cardboard cut it with an X-Acto knife and a small command strip that was cut then put it on top of the fan connector so it would wedge against the bottom metal plate. And it worked! Thanks for the tips though
Questa è una buona domanda?
Punteggio 0
3 Commenti
What did you do before you noted the fan had failed?
da
before I noticed the fan failed I was watching YouTube
da
Lets get a better view on whats happening. First remove MacsFanControl, then install this app TG Pro it allows you to see everything in better detail. Take a snapshot of the main window so we can see all of the sensors and the fan info (you may need to stretch the bottom a bit) and post it here for us to see Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
So we can see the thermal sensors are all working correctly which is a good sign! You still could have one of the other SMC sensors on the logic board failing. Clearly the fan is not reporting its RPM so I’m suspecting the tach unit within the fan has failed.
You might want to run diagnostics to see if any errors pop. Restart the system and press the D key. Did you get any error messages?
At this point I would replace the fan unit MacBook Pro 13" Unibody and MacBook 13" Unibody Fan to see if that solved the issue. If not the logic board fan control logic is damaged.
Immagine MacBook Pro 13" Unibody and MacBook 13" Unibody Fan
Prodotto
$29.99
Punteggio 1
Aggiungi la tua risposta
Ronan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 70
