Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
It will not set up
I recently got the screen changed on my iPad 3. It is reset and when I go to set up, it gets to the “it may take a few minutes to set up” message and then after a minute it simply starts back over like it is a new iPad needing to be set up. How do I fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Before opening up the iPad make sure the iPad is up to date via iTunes and 3utools. You can also use 3utools to activate the iPad.
Punteggio 1
Try taking all the ribbon cables out and putting them back in.
Punteggio 0
Aggiungi la tua risposta
Cody Slovensky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 70
