Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel novembre 2016, questo MacBook Pro introduce la Touch Bar OLED. Ha CPU Intel Core i5 dual-core "Skylake"e 4 porte Thunderbolt.
239 Domande Visualizza tutte
Another Screen Problem. Apple has to do something.
My 2016 Macbook Pro screen is faulty like many other computers like mine. I saw this post that explains whats been going on and it shows how this problem is a design fault.
https://ifixit.org/blog/12903/?utm_mediu...
Apple has to address this issue urgently.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Almost! You have a different problem than FlexGate.
In your case your issue is more likely this Water damage to screen? If you haven’t spilled anything then you may have cooked your system in a hot truck which could have curled the defuser sheets and/or the polarizer sheet within the screen assembly. Here’s a view of the sheets from the MacBook Pro Retina Display Teardown
Sadly its time for a new display assembly ;-{
I would recommend you visit an Apple Store to see if you can convince them it’s a parts failure.
Punteggio 1
You may be covered under this new program
https://www.apple.com/support/13-inch-ma...
Punteggio 1
Aggiungi la tua risposta
luiz bacchi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 76
