No sound at all and mic not working
I am not getting any sound from my phone through speakers or headphone Jack. Also the mic is not working, I can't talk to anyone during a call. Is there a way I can fix myself?
Questa è una buona domanda?
Hi,
Try starting the phone in safe mode to see if it works OK.
If it does then a downloaded app is the cause of the problem.
You’ll need to uninstall each downloaded app (start with the latest ones installed or updated), one by one and test the phone in “normal mode” between each uninstall. When the phone works correctly then the last app that was uninstalled is the culprit.
If it still doesn’t work OK in safe mode, try resetting the phone, using the phone’s factory restore feature, to check whether it is a hardware or a firmware problem.
Perform a backup of the phone, using the phone’s backup feature, before doing a factory restore.
Be aware the a factory restore will erase all your data and downloaded apps. It will restore the phone to its’ factory default (or last updated) condition. It will be like when you first bought it. That is why it is important to backup the phone first.
Once the backup has been completed, factory restore the phone.
When the factory restore has been completed check if the phone works normally.
If it still doesn’t, then you have a hardware problem.
Is the headphone icon on all the time even though the headphones are not installed? If so, I’m just wondering if there is a problem with the headphone socket.
Has the phone been dropped or gotten wet at all?
In any case it will have to be opened and the problem further investigated.
Here’s a link to the ifixit Samsung Galaxy J3 guide, which may be of some help.
If it works OK in factory default mode , using the backup that you made earlier, restore the phone to what it was using the phone’s restore feature.
When the phone has been restored check that it is still working OK.
If it does, then the reset has resolved the problem
Thanks for the info but I think it's a hardware issue cas it had an electric surge go through it and it shut the phone off immediately. When I turned it back on that's when the speaker and mic issue was noticed. I haven't found any tutorials on how to take my exact phone apart. It's a Samsung galaxy j3 "pop". Ive seen tutorials for other j3's however they're different then the "pop". If you know of a tutorial please point me in that direction. Thanks
Hi,
It may be better if you edit your question to include the new information regarding the "surge" and the actual model teardown problem etc. This will help others who may want to answer.
Go to your question Options > Edit
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 24
Tutti i Tempi: 9,144
