Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
black spot in left corner and lines vertically through display
i dropped my iphone 6s plus and when i picked it up i noticed there was a green line running from top to bottom and the bottom left corner showed no display. after a day of using it like that a blue line appeared about half an inch away from the green one. my question is, if i get a screen replacement will that fix that issue or is that an internal problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That sounds like a screen issue. Unfortunately, the only way to know for certain is to try a known-good replacement screen. If you buy the screen from a reputable vendor, you shouldn’t have any issues but be wary if you buy a low cost screen from eBay or Amazon as the failure rates are much higher.
You can follow this guide to do the repair yourself.
Punteggio 1
Aggiungi la tua risposta
Hunter L sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 259
