Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Can I use an iPhone 6 Home button on an iPhone 6s?
I have a customer that broke there screen and the home button cable ripped and I don’t have any iPhone 6S home button fin stock. Can I use an iPhone 6 home button on a 6S?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No, they are not cross-compatible.
When in doubt, take a look at the product listings here on iFixit…they will state if a part can be used on more than one device.
iPhone 6/6 Plus Home Button
Immagine iPhone 6 and 6 Plus Home Button Assembly
Prodotto
$19.99
Punteggio 3
You might be able to, you might just have to test the fit before you actually insert it into the device. Also check the ribbon cables to make sure that they will fit and reach.
Note that the Touch ID functionality will be lost.
Punteggio 0
2 Commenti:
Please remember that these are electronics components and as such, there are sometimes surprisingly high voltages powering these parts. If you "just test" something without understanding what you are doing, you can cause some serious damage to the logic board because you are shorting pins that would not be normally shorted because Apple tends to change the layout of the connectors from one device to another.
Please refrain from suggesting someone try something to see if it works if you don't know what's in play and you haven't researched it or tried it yourself.
da
@refectio Well said, I fully agree and subscribe !
da
Aggiungi la tua risposta
Owen Baker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 82
