Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Flickering issue on primary display, external display seems fine
Hi all,
I have a mid 2012 MacBook pro that has been experiencing this rare issue. the main screen flickers randomly but my external screen seems fine and I could still use it normally.
Is this a screen issue or a GPU graphic card issue?
Thank you a lot!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It’s not the integrated GPU, which is a good news, as a faulty graphics issue would be showing up on the external monitor too. However, ruling out the Gpu doesn’t make things much easier as the fault could still be on the logic board, Lvds cable and screen. You would need to have a screen assembly to try out to progress further in troubleshooting, or start probing the Lvds connector, which is not a typical DIY repair.
Punteggio 2
2 Commenti:
Thank you Arbaman, I will swap the screen with another one (hopefully I find one soon for sale) and will let you know how it goes.
da
Here's the needed part MacBook Pro 13" Unibody (Mid 2012) Display Assembly and the guide you'll need to follow to put it in Sostituzione schermo MacBook Pro 13" Unibody metà 2012.
da
Aggiungi la tua risposta
renzogmx sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 61
