Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Started her up, as usual. Immediate loud clicking (whirring?) noise.
As said, I did my normal start up, and there was an immediate loud clicking noise, along with a whirring sound I guess? It was loud and scary enough that I shut her back down (properly) and have kept it off since. I contacted apple, went to two geek squad locations, and two computer places that I guess are apple-certified? The guy with apple recommended them because of my laptop’s age. I have legitimately never had a problem with this computer until this. Every person I talked to said it was probably the hard drive and nothing they can do. Could it be anything besides the hard drive? What else can I try? Having had zero problems with it in the last almost decade of having it, makes me skeptical that there’s “nothing that can be done”.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Well it’s definitely the hard drive if they took it out and tested the drive for clicking noises.
You can check whether the noise is coming from the hard drive or something else. Disconnect the fan as shown in this guide to step 5:
Sostituzione ventola MacBook Pro Unibody 13" inizio 2011
Once you hear loud clicking see if it also happens after disconnecting the hard drive as well, you can use this guide to remove the hard drive:
Installazione Disco Rigido nel MacBook Pro Unibody da 13", versione inizio 2011
Immagine MacBook Pro 13" Unibody Early 2011 Disco Rigido
Guida
Difficoltà:
Moderato
30 - 45 minutes
Immagine MacBook Pro 13" Unibody Early 2011 Ventola
Guida
Difficoltà:
Moderato
20 minutes
Punteggio 5
3 Commenti:
Time to upgrade to a SSD, never seen them so cheap..
da
Yeah, they actually didn’t even bother opening it up. Just flat out said it’s too old for them to do anything, basically. Real helpful, right? Ha
da
If you upgrade the drive, it is advisable to also change out the hard drive/IR cable with the one from the 2012 13" model.
da
I suggest not to waste time and run around. Just replace the drive and transfer the data before it is dead. The only thing that can make the clicking noise are the DVD ROM and the HDD.
Punteggio 0
Aggiungi la tua risposta
robynfoulks sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 54
