Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
I dropped my phone but there is something weird about it
So I dropped my phone today. It was not working at all so I read on this website to leave alone for a while so when i did it worked. But the problem is I cant get into my phone because half of it is covered with lines and some of the numbers for my password for my phone are covered in lines. HELP ME PLS!!!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
When your device has lines on the screen, there’s a chance that your iPhone 6S has been hit so hard that the LCD cable has managed to disconnect from the logic board.
The LCD cable needs to have all the pins connected to the logic board in order for your screen to look normal.
There are a few things you can try and do because you can conclude that the device is damaged.
  1. Force Restart your iPhone
  2. DFU Restore your Device
  3. Push Down on your Screen Firmly
  4. Repair your LCD Display
Hope this info is helpful!
Punteggio 1
2 Commenti:
OMG thank you soo much I will try it and get back to you!!!
da
Thank you, and look forward to hearing good news soon from you.
da
Aggiungi la tua risposta
Kylee Felczak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 74
