usb 3.0 not talking with devices connected to it
the usb 3.0 port still has power but any device connected to it
will not talk with the computer
any know how to fix this
as give me some idea
Thanks
Questa è una buona domanda?
Thanks
Hi,
Couple of things to check:
a) Check in BIOS to see if the USB has not been disabled.
Press F2 on startup to enter BIOS go the the Security tab and then select the USB interface security option.
If it is disabled, enable it, save the changes, exit BIOS and restart the laptop.
b) Go to Device Manager and check the status of the USB 3.0 controller. If there is a yellow exclamation mark against the entry, right click on it, select update drivers and follow the prompts.
Have you checked to make sure you have the correct driver installed? What os are you using? If you have the right drivers try uninstalling the device, also deleting the driver files then connect it again.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 201
