Salta al contenuto principale
My tv won’t turn/power on after being unplugged for a couple of hours
I moved my tv and then moved it back to put it back on and plugged the tv back in, no lights or anything came on when I plugged in back in. I have changed the fuse in the plug, the power cable and the socket.
Questa è una buona domanda?
Punteggio 1
2 Commenti
I had the same problem with our sony. later on we found out that it was a burned out screen bulb in the tv. We took ours for a tv trade in to get money off our new tv.
da
Hi @k12 ,
What is the model number of the TV?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hello,
If you had been check a all things means cable and power supply then you should talk to your customer service and talk to where you purchased it.
Punteggio 1
get it checked from some professional technician or if your product is under warranty, take it to the service center maybe some internal problem is causing this issue.
Punteggio 0
Aggiungi la tua risposta
Kier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 10
Tutti i Tempi: 861
