Salta al contenuto principale
Toshiba Satellite C55-A5281 - 15.6" - Pentium 2020M - 6 GB RAM - 750 GB HDD - US
2 Domande Visualizza tutte
Dead section on right side of screen
Why, or, what would cause a certain area of the screen to not respond to the cursor? Either with a USB mouse, track pad or touching the screen itself. I have had this problem for some time and after researching the problem it was determined that my digitizer screen was the culprit. Last week I replaced the screen (digitizer) and after about 30 minutes of use I went to the area that gave me trouble in the past, only to find out it’s still a dead area. Using a stylus, USB mouse, or the touch pad. One thing I might add; some of the areas will let me “tap” an icon and move it up, but not down, as well as some will let me move left but not right.
Could it be the complete screen itself?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Sorry, do you mean you can't even click anything on one side of the screen even with a normal mouse (not a touchscreen)? That doesn't sound like a hardware issue, maybe a software problem.
da
That is correct, roughly a 3" X 3" area of the screen; right side just below center. Touching with the stylus, using the cursor with the touch pad, or using a (USB) mouse.
da
Aggiungi un commento
1 Risposta
It doesn’t sound like a hardware issue to me if you can’t even click in the section with a mouse. I would try booting to Safe Mode and see if the problem persists. If that fixes it, it means some application or driver you have installed is causing the issue.
I would also probably try a MalwareBytes scan and reinstalling your graphics, keyboard, and mouse drivers.
Punteggio 0
Aggiungi la tua risposta
Ken Short sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 156
