Salta al contenuto principale
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Does not boot up
Hello everybody,
My old macpro 1186 from 2007 stopped running after installing software.
I tried tocopy a folder on the desktop from a usb stick but with no success therefore I forced quit finder.
After that every folder, including HD icons, disappeared from desktop so I decided to power off from I/O button.
When restarting the machine stays stuck on tje gray apple logo
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @daniele3180
Somehow I have a feeling the harddisk might be failing.
da
What would you suggest?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
See if it will boot from the original system installation DVD. To do that load the disk (hit the eject button in the upper right corner of your keyboard to open the tray). Now reboot and hold down the C key. Now see if you can run Disk Utilities on the internal hard drive.
Punteggio 2
H i Daniele,
Have you tried looking into the the Apple discussion boards? Here is an example of the same problem that you are having that may help you https://discussions.apple.com/thread/507... . If that doesn’t work there is a good possibility that you hard drive is going south and you may need to replace it.
I hope that this helps you.
Jim
Punteggio 0
Aggiungi la tua risposta
Daniele Guidi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 127
