Salta al contenuto principale
Repair and disassembly guides for electronic keyboards.
214 Domande Visualizza tutte
it does not turned on anymore.
I have a Yamaha PSR-S750. My daughter pulled the adapter which turned off the keyboard, but when I tried to turn it back on, it does not turned on anymore. So I bought a new adapter, but still didn't work. What might be the problem and how can I fix the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @eyatilman ,
Check that the DC input jack has not been damaged and also that the fuse on the AJACK board is OK.
After that you may have to go further into the circuit to determine what the problem is.
Here’s a link to the service manual for the keyboard.
To download the file when the sentence below the Document preview box changes from This file is downloadable free of charge: …processing…to This file is downloadable free of charge: Download , click on Download as this is the link. Be patient it takes a little while to find the file.
Here’s an image taken from the manual showing the relevant section of the circuit
(click on image to enlarge for better viewing).
The manual has a full parts list which will help if you need to obtain a replacement part.
Punteggio 1
Aggiungi la tua risposta
Elias J Yatilman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 127
