Salta al contenuto principale
Repair guides and support for Ematic tablets.
My ematic tablet is not working
Hi. I bought this tablet a few days ago and it stays stuck on the screen logo. Now when I turned it off again and pressed the power button and the volume buttons it took me to the recovery screen but I also get the Android man laying down saying no command(separately). When I went back to the recovery screen I tapped the recovery system to reboot and I pressed the power button. It went off and came back on but it is still stuck on logo screen. I really like this tablet so please help or any suggestions. Thank you
Questa è una buona domanda?
Punteggio 1
1 Commento
I received a tablet for Christmas the tablet never came on I tried charging it never turned on the customer service number is not working can’t get in touch with no one
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
What is the model number of the tablet?
Have you tried pressing the reset button for about 5-10 seconds, to see if this resets the tablet back to normal?
It is found on the back of a lot of Ematic android tablets
You will need a pin or opened paperclip to operate the button as it is recessed in a hole in the back cover.
Do not confuse the hole with the microphone inlet hole. You may damage the microphone if you shove a pin in there.
Check the tablet’s layout description in the User Guide that should have come with the tablet to help verify the reset button’s location, (if it has one that is).
Punteggio 1
8 Commenti:
I am having the exact same problem except mine has no reset button . What can I do?
da
I am having same issue
da
I received a Ematic tablet for CHRISTmas and it won't allow me to download from the play store. Error 403 not certified(???)
How does one get certified? Want to throw it out the window already!lol
Ty4 in advance 4any response to this.
MerryCHRISTmas& HappyNewYear
da
@Theresa Griffith
Assuming that you can get online OK try updating the Play Store app and check if that resolves the problem.
Launch the Play Store app and then tap on Settings in the app, scroll down to Build Number and tap to enter and follow the prompts.
da
@Theresa Griffith
I had the same problem what i did was that i had to change the time because it was wrong maybe you should try it
da
Mostra altri 3 commenti
Aggiungi la tua risposta
Karyn Moore sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,975
