Salta al contenuto principale
Guide e supporto per varie marche e tipologie di televisioni (TV).
9055 Domande Visualizza tutte
Magnavox 40ME313VF turns on then back off. Power light blinks 5 times
I have a 40 inch Magnavox 40ME313V/F7 tv. When I plug it in the red led light comes on. Then when I press the power button the led will blink 5 times and power on for a few seconds, It does show the Magnavox logo then I hear a static sounding noise from the speakers, and it turns off. with the led light still on solid. When I press the power button again the led will turn off, after pressing the power button a few more time (5-6 times) it will turn back on solid. Then I can hit the power button again and the led will blink 5 times and turn on for a few seconds and show the Mganavox logo again and I hear the same sound and it turns off again. This can be repeated many times over and over.
I have looked for anything obvious on the boards such as burn spots blown caps, ect. can not see anything wrong. I disconnected the t-con board and same thing happens with the exception of the logo of course, the back lights do turn on. Below are some pictures of the boards.
Right now I am thinking it is the main board, anyone have any other ideas on with it might be?
Questa è una buona domanda?
Punteggio 0
1 Commento
I was having the same problem on a magnavox 50 inch but with 11 blinks my tv got hit by lightning and I have replaced both boards the iR sensor and some strips turns on shows logo the shuts off with noise from the speakers I dont know what else to do from replaceing stuff but it does turn on now as of before the new stuff it did nothing
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
At this point, I would think of replacing the IR Sensor. We have found that most of the time that is the cause, of your TV turning on the shuts off--Go into the back of your TV and carefully clean the IR Sensor flex cable-- and see if that will get your TV to come on---If not just replace it--Also check Power Board for bulged caps, but I don't think you will find any--
Update (03/07/2019)
All right I just spent the better part of the day digging and searching for you and bugging people i know that know people to get this info straight from one of the lead Magnovox techs in Japan..
here is what he told me..
Although Magnavox has no error codes-5 red blinks is related to the power board-Pop is related to the Power board-
Getting to screen logo is related to Main Board, but can be caused by a voltage supply problem, to the Main Board coming from the Power Board itself-
We have been fixing 5 red blinks with a Power Board replacement-
he also said in rare cases that after the power board is replaced that the Magnavox 40ME313V/F7 A3AP1UH Main Board IC3006 EEPROM  might also need to be replaced..
I hope this helps..
p.s. your model number was not in the correct format ans very difficult to locate any info at first because of this..
40me313v/f7 and then there are some variations to this with a number or letters following behind the model number..
Punteggio 0
5 Commenti:
There are no bulged caps anywhere, I will be getting back with the customer and seeing about ordering the IR Sensor.
da
@digitalfubar I just got the new IR Sensor board in cleaned the cables installed the new IR Sensor and still have the same results. I did look over the boards and did not see any bulged caps anywhere. Have any other ideas?
da
Also if you dont have the service manual here is a copy.
https://drive.google.com/open?id=1C9bS7k...
da
answer updated. …………….
da
My tv will power up and show the magnavox logo on the screen then it shuts off and makes a clicking noise repidatively until you puke the plug. Any thoughts?
da
I had the exact same issue. It was the main board. PSB was fine, although all symptoms looked like a PSB problem
Punteggio 0
2 Commenti:
I had the same issue with a 50”. It was the main board. PSB was fine
da
I've got the same problem with my 55 inch. Just started last night. I am not technically inclined so I cannot work on it. Looks like I'll be buying a new TV after Xmas but it won't be a magnavox
da
Aggiungi la tua risposta
Brent Norris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 105
Tutti i Tempi: 13,803
