Salta al contenuto principale
The Dell Inspiron 15-7559 is categorized as a gaming laptop, featuring a 15.6" screen, full keyboard with number pad, and 3 USB 3.0 ports.
10 Domande Visualizza tutte
WiFi Range almost gone
Hello,
As many other people experienced, the display hinges of my 7559 became loose. The threads where you screw in the display broke off on the left side. As a consequence, whenever I closed/opened my screen, the hinge moved as a whole and lifted the top part of the case up. I fixed this by buying a new bottom base and migrating the laptop to it. At the same time as the hinge started to malfunctioning, my WiFi signal all of a sudden dropped to 1 bar, even though I’m sitting right next to the router. Also, it didn’t detect any other WiFis, even though there are usually about 8 other WiFi networks. The problem even remained after exchanging the white and black antenna cables on the wifi card with each other (meaning I plugged in the white cable where the black one was, and the black one where the white one was). When I use my phone as a hotspot and extend my arm away from the laptop holding the phone, the signal dropps to 1 bar. The closer I get to the laptop/screen, the stronger it gets.
Dell said that it might be the antenna cable. Since I don’t have warranty it would cost me around 200€. Any ideas what I can do before sending it in? I assume the antenna cables are the issue, but it might also be the WiFi card, though I dount it..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @aria25 ,
It might be that the antenna cables have been damaged in the hinge area as this is where they pass through to the lid.
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.80 to view the necessary pre-requisite steps and then the procedure to remove/replace the display assembly. This will allow you to replace the antenna cables.
Here’s a link to just one supplier of the part. It is shown just to give you an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Dell Inspiron 7559 WiFi antenna to get results for suppliers of the part.
Punteggio 2
Aggiungi la tua risposta
Aria sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 787
