Salta al contenuto principale
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127 Domande Visualizza tutte
2012 Samsung Galaxy Note 10.1 with slow charging issue
I cannot seem to get this device to charge at a decent rate. When plugged in, it only pulls 0.83 A at 5.65 V. I have installed a new battery and have also reset the device, several times, each time it works marginally better for a while, then back to slow charging issues again. I have tried several different Samsung charging units and cords, all with the same outcome, slow charging.
Should I be looking for a deeper issue?
Thanks for your help.
JK
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
If you have done all the steps like changing battery and resetting. It seems more like a motherboard level issue instead of a battery / charging cable issue
Punteggio 0
I find that a lot of the time the battery is “Below voltage” You will to connect a power supply directly to the battery pins in order to boost it to a level it will charge, Plenty of guides on how to do this
Punteggio 0
Aggiungi la tua risposta
J.K sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,709
